Chris - the good news is that we don't have to deal with China directly like we did 4-5 years ago. These large prismatics, like GBS, CALB, Winston, etc are available from a number of stateside EV and specialty battery outlets. I personally use GBS cells.
One you might want to look at is
Elite Power Solutions in Tempe, AZ. They specialize in the GBS cells, although I have no firsthand experience with them. I got mine from BatterySpace.
That being said, remember that the manufacturers and distributors are catering mostly to the EV market, and may have never heard of "solar insolation hours", nor the generic rule of not sizing your battery bank to go below 50% DOD. Since lifepo4 is usually taken down to 80-90% DOD by EV'ers and is the standard for rated cycle life, they may be grossly underestimating your capacity needs, even if the data you gave them was perfect.
For best results, we normally eschew "growing into" your battery needs, as this usually results in one or more complete rebuilds of most of the existing infrastructure, not to mention generally poor battery operations with batteries of different age and use patterns.
If you can give us an idea of how much power you are using now, or are planning to use, we can figure out probably much more accurately than a battery manufacturer or EV shop can - or if it is even within the range of reality.
Large prismatics like the GBS and CALBS can easily handle 1C of current, with 3C bursts (on average) but of course, your battery would last a little less than an hour, so that kind of pull, even though it can be done, is not realistic for a house-bank. Still good news for huge surge loads.
If you can give us a better idea of how much power you intend to pull, we can see if it can be done - on both the discharge AND solar recharge capability. Perhaps if this was restated in a fresh new thread we can keep a better handle on it.
