I can tell you exactly what you are doing wrong. You cannot use solar to EQ, it has to be either commercial AC power or a generator with a good battery charger. Solar is not capable of fully charging batteries let alone EQ. That is why an off-grid system must have a generator. Generator is used once a week to top off batteries, and EQ as needed. It takes up to 24 to 36 hours to EQ a battery with uninterrupted charging.
EQing the battery
"I can tell you exactly what you are doing wrong. You cannot use solar to EQ, it has to be either commercial AC power or a generator with a good battery charger."
Then you'd be exactly wrong. I use the grid to EQ. I also used the grid to run a 3 hour absorption before I started the EQ. But thanks for the input. Everything is appreciated.Last edited by Hotrod; 06-26-2019, 07:04 AM.Too much stuff for 50 charactersComment
Commercial AC power is also known as The Grid.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
"I can tell you exactly what you are doing wrong. You cannot use solar to EQ," sounded to me like you made the assumption that I had EQed the battery off grid using solar alone, so I responded to that effect. My belief that you made an assumption is further reinforced by your explanation of generators and grid power as stable sources to conduct an EQ.Last edited by Hotrod; 06-26-2019, 09:28 PM.Too much stuff for 50 charactersComment
