I've seen charts that show battery banks at only 35% of rated capacity when the outside temp. hits -20 degrees F, which is about how cold it gets where I live on the coldest couple days of each winter. But in order to stay safe and keep a FLA battery bank vented I'm assuming that the vented enclosure must be located outside of the home. If that is the case, how do you keep them warm so they deliver their rated capacity (to 50% max) in the winter? Need some ideas.
Need ideas on how to keep a 24V batery bank warm in the winter (6V x 4 bat)
It actually diffuses so well that with any ventilation at all the concentration should not get dangerously high.
If you put your batteries outside and insulate them very well the normal heat from charging and discharge might keep them at a usable temperature range anyway.SunnyBoy 3000 US, 18 BP Solar 175B panels. -
Done every day around the world, routine with outdoor cellular cell sites, not so much with Solar but a few. I have several sites in NN and AZ at altitude. Some AGM, some FLA.
When outdoors you just have to design for it. Batteries are odd things. When hot they have higher capacity but shorter lives. In cold they have lower capacity and longer lived.
-20 is not extremely cold for a battery if it is charged up. AGM is almost impossible to freeze. Trick is to select the right battery type, and adjust capacity for the temperature. -20 F is no problem for FLA assuming you can get it charged. Even less of a problem if you are only talking brief dips to -20 infrequently. Insulation will help coupled with proper charging will heat the battery, and thermal mass all help.
What you have to do is size the battery to account for the capacity loss, and up size the panel wattage to account for larger battery and short days of winter. That could bring about exceeding C/8 charging and force you to use AGM.
Completely workable, all it takes is money.
Smart money is bring the batteries inside as Dave suggested.MSEE, PEComment
No. Because AGM can also vent, you will need a robust battery containment system for either type. So I'd just use Flooded.
The box needs to be a swimming pool to contain spilled acid, and the lid needs to direct fumes outside the dwelling.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Would you use flooded inside a van converted to rv (Class B) with the same battery containment system?Comment
Silver bringing FLA batteries inside is no more dangerous than having a wood/coal burning stove or fireplace in the house. Figure it out, you are smart enough.MSEE, PEComment
Also good choices for EV's. Trick is they cost big bucks. So use then where you can justify the expense.MSEE, PEComment
Since AGM can vent under certain conditions, their box must be vented outside the inhabited space, like you would plain flooded.
But you can insulate an outdoor battery case for winter usage.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
MSEE, PEComment
