Chris you were beating your chest about Aquion carbon technology right? Is it just because it is Trojan you do not like? 90% of all lead acid battery failures are due to sulfation on the negative plate, and remaining is corrosion on the positive plate. By adding Carbon to the negative plate prevents or drastically slows down lead sulfate from collecting and hardening on the negative plates. That is a huge gain. The only downside is it reduces specific energy density, but that is no consequence for stationary RE application, not good for EV, but no problem for RE as all it means is more weight and volume required. That is a very good trade getting possible 10,000 to 30,000 cycles for a little extra weight and space.
Only negative thing I can say is prove it. Not to just Trojan, but all that manufacture PbC batteries. I will give them a benefit of a doubt because third party testing strongly indicates their is something to the claims. The true test come from the feild users like yourself. It will be a game changer if they can make a battery that can last 10+ years without loss of capacity and operate PSOC.
