As long as the little BMS can dissipate the excess power the charge device is sending to the battery, you are OK. Most BMS 's cannot and will simply disconnect the battery when the voltage becomes dangerous, That won't be fun if you have to manually reset every day
Trojan absorbtion voltage
An example of a MPPT manual using the same terms as TrojanAttached FilesComment
MCU algorithm adjust voltage setpoint,
This is not Constant Voltage, not Constant Power.
Back to basic MPPT, this maximum power Point charging.
DIY person can do that with arduino, etc.
[QUOTE=Niron;n419893]
You know DIY terms.
Not for you to discussion my diy powerwall.
QUOTE]
In the country where I am currently living you Niron and I reguarely see examples like this. I hope you don't consider these as well designed & safe systemsAttached FilesComment
