That is what smart money would do. The key to your success is properly sizing the battery for your daily needs and size it for 3-day capacity. By doing that will give you 2-days of use without recharge in the event Justin Case shows up with his wet blanket and poops in your Post Toasties.
As a side note I should have thought about Genasun as they specialize in Marine and Golf Cart products which make them a Niche supplier and not many uses for them so they get tossed back in the closet of my mind. Their Boost Controllers are aimed directly at the Golf Cart market using a 24 volt solar panels as the roof to charge 36 and 48 volt batteries. Like I said if given a choice you want to go from Higher to Lower voltage aka Buck Converter which is what 90% of the Controllers use.
