I can help you,
No u can't
- Ur too busy trying to prove how smart u are and how smart I am not.
- U haven't the slightest clue what my facility needs in terms of power
- I don't want your help
You cannot go off-grid without knowing much about power and batteries.
I hired the wrong installer. Pretty simple.
If i buy a car that's a lemon, Im not mad that I don't know how to fix it. Im mad at the dealership. Professionals have to be able to do their jobs.
There is a way to fix your issues.
Allow me to explain a couple of things.
A fifth grader can do that.
3. Sell one of your 100-Amp Controllers,
4. Sell off 1000 watts of your panels, you will not need them once you remove all that heat load. That leaves you 5000 watts and that is way more than you will need.
I need more panels actually. I need to have appx 8k of power available on a hot sunny summer day. I was getting by with 4k watts. It's much cheaper to set up a 8k watt array of panels & 8k worth of inverter for float usage in summer months than a battery bank that (a) will never get charged due to my loads and (b) last 12 hrs a day with 6000w loads on it.
Replace your batteries.
I spent 2 hrs on the phone with Magnum tech support. They went over my entire system with me. They found 4 major setup errors that we addressed and they didn't give me the impression my situation was as dire as ur convinced it is. In fact, Ive spoken to 2 electricians, 1 generator expert, and 3 solar companies. Not a single one made any of the suggestions you have. They did find errors in the setup tho. And we might have found the issue. I'll know exactly after a site visit.
Keep reading this until you understand,
He screwed and tattooed you blue.
You allowed that to happen and no one to blame but yourself, not the messenger.
The only difference between u and I is I know how little I know about my solar system.
