Grid Tie Battery Bank - AGM sealed or deep cell?
Maybe so, but I was also led to believe the surge on my Fridge was higher than the only 800 watts it ended up being.... turns out the battery rep on the phone at some company was right all along when they said I may not even need a battery and could power my fridge and pellet stove from a 1,000w inverter.
MrEnergyCzarComment
So would the solar panels have to be all rewired to a different voltage as someone said earlier?Take a picture of your sun power inverter and get Amy serial
Numbers from it. It is most likely anSMA inverter. You can add a sunny island and batteries to create a 120V back up System. If you need 240v it will require 2 sunny islands. Your 12v inverter will not work with a 48v battery bank
Thanks
MrEnergyCzarComment
If you keep signing your posts with Mr Energy Czar I am going to start making a footnote each time.
We have very few visitors that are as clueless as you![SIGPIC][/SIGPIC]Comment
Most likely no.
Using the Volt as a power source from what I can see would be a very small 12V load. There is no inverter built into the car and you would be using the accessory battery only from what I can see.
Try contacting the contractor that put the system in for you and tell them what you want to do. You are probably still under warranty and any diy modifications would most likely void your Sunpower and installer warrranties.NABCEP certified Technical Sales Professional
Sorry but I have gone as far as I am willing to go with you and ran out of patience... You just lack any basic concepts of energy production and math skills which makes you ver dangerous to yourself and others around you. .MSEE, PEComment
Thanks for all the help. Any advice on how to find someone who actually installs battery back-up systems in CT? Realgoods bought my previous two companies I used, solarworks and whomever bought them, I think alteris.Most likely no.
Try contacting the contractor that put the system in for you and tell them what you want to do. You are probably still under warranty and any diy modifications would most likely void your Sunpower and installer warrranties.Comment
