Make Battery Last Longer
That is important. I thought the switch (or connector) connecting the battery to the motor might
That's a big IF One mistake, leaving the PV connected in the dark - will drain the battery. Parked in the sun
between flights, might overcharge, depending on battery SoC.
So, I'd add a schottky diode as a reverse bias prevention, and a 5w zener as overvoltage protection.
have an extra pole to connect the panels. Avoid a zener that size which needs a heat sink. BruceComment
Mike90250, Your suggestion was right on. Ditching the charge controller and just adding the schottky diode and a 5w zener has given us the best results. One question, do you see the need to also add a capacitor to the circuit? Thanks!
Orbit-Solar (1).pngComment
Great, I'm glad it worked. One thing worries me, you have a 12V zener as protection against overvoltage on a 11.1V battery, that seems to be beyond the safety margin by 1.5V or so.
The large capacitor is not needed, unless the zener generates enough noise/hash that it interferes with the plane's radio, then a much smaller capacitor, 0.1uF / 30V ceramic disc would help.
Mike90250, We used the 12V Zener because this battery is at 12.4V when it's fully charged. Won't a lower 11V Zener attempt to bring the battery down to 11V(10.45-11.55)?Comment
If they are li-ions then they are good up to 4.2VPC, or 12.6 volts total. So a 12V zener should work OK as long as it doesn't remain connected during "normal" charging.
OK on the zener voltage. I just wanted to be sure there was not going to be a problem
Where did that come from ?Originally posted by OscarThey should adjust and counteract one another, including boards includes weight and drag, to counterbalance that you should add push capacity to produce more lift to convey a heavier plane, to do that requires more power from the power plant...
