Tesla Powerwall, The Specs, Numbers, and Implementation Absolutely Brilliant
I understand there is a very small base of off-grid users who are upset that Powerwall does nothing for them. There's a guy on the Tesla forum who rants about this daily. But the on-grid manufacturers (i.e. 99% of the PV industry) have been using high voltage DC for some time. And as storage is added to the on-grid mix I suspect that 48V DC is just going to go away.Comment
I'm looking at installing a PV system for about $3.50 per watt. But I live in Texas where electricity is cheap and net metering not very favorable (I can net energy cost, but not distribution cost). So even with local and federal incentives the economic case is marginal. Adding Powerwall to the system will increase cost by about $1 per watt, but it provides an important secondary benefit as a grid backup system. It's hard for me to place a value on this, but it isn't small given that I can't run a generator here so I have no other backup options.Comment
I'm thinking about it. I enjoy hearing other people's opinions, especially those critical of the product, and they are very much contributing to my decision making process.
One of the reasons I have both generators and batteries is to provide a power source for my mother in law's oxygen machine. That needs to work at night even if the grid is down.
You have limited choices and none are cheap. I hope energy storage prices come down and you find a way to feel safe and secure with your choices.Comment
MSEE, PEComment
Actually NEC code doesn't allow residential batteries over 50V at all. So it's not completely clear how Tesla plans do get UL approval for Powerwall, but I presume they have a plan. It seems Powerwall works the same way the battery in the Tesla car works: it won't deliver any current unless a normally-open relay is closed by some external controller (i.e. the inverter). This is a significant fail-safe improvement over existing batteries and I suspect overcomes any objections on safety grounds. Oh and it costs virtually nothing - it's just smart engineering.Comment
I do not know what your background in solar is, but it's apparent, that you have none.
There is a large base of educated users whom are upset that the powerwall is a poor product with a lot of hype behind it.
Some Grid Tie systems use high voltage DC but the powerwall does not have an integral charger, so that would have to be purchased separately. It may pass NEC by the fact it's a sealed "box" with no accessible parts.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
So wrong. sigh....
No need to purchase a separate charger: all you need is a SolarEdge inverter and the Powerwall battery. Watch for the SolarEdge demonstration and press release next week. Wish I could tell you more but I don't want to spoil the surprise!Comment
Ditto been doing this professionally for 35 years. Have installed hundreds of systems with 200 plus battery volts on UPS systems with FLA open cells. Passed every inspection even in NEW YORK CITY AND CHICAGO.
So please enlighten us on your expertise. Warning I sat on the NEC code panels for 2 cycles, and a moderator on MH NEC code forum. Even taught a few classes for MH.MSEE, PEComment
"Storage batteries for dwellings shall have the cells connected so as to operate at less than 50 volts nominal. Lead-acid storage batteries for dwellings shall have no more than twenty-four 2-volt cells connected in series (48-volts nominal)."
I am not arguing that is the whole story. There are exceptions included in the above section, and I'm sure you need to read this section in conjunction with a million other sections/rules/policies whatever. But I didn't just make it up!Comment
