Ok whoa whoa whoa, I'm terribly sorry if I'm coming across as hard-headed. I'm by no means a veteran solar panel user. But I am an avid astronomer and electrical hobbyist. So I know my numbers pretty well. Think maybe I've generated some confusion on here by how I've put my numbers across and perhaps have been focusing too much on theory and not practice. If one goes back through my posts one will see I've quoted both space figure and ground figures. When claiming annual figures I certainly have taken into account the earth's shape, rotation, latitude, axial tilt, day/night hours, sun angle and average atmospheric conditions. What I haven't taken into account is panel orientation, production characteristics and diffuse light. Based on the 3 months of data I've collected from my own system my numbers seem correct. I have an 880watt array without an MPPT controller so it behaves more like a 650 watt array. Gaisma quotes a June figure for Port Elizabeth of 2.5kwh/m2 per day. My array covers 6m2 and has an efficiency factor of 16%. I won't bore with the calculations but they work out that I should be getting about 2.5kwh per day. I get 3.5 on a sunny day and maybe 1 or so when it's cloudy. Averaged out I can easily agree with the 2.5 figure. Now Gaisma quotes figures of between 7 and 8 for the northern cape in summer and over 3 in winter. Average annual is about 6. Multiply 6 by 365 days of the year and you get nearly 2200. Still very near my original calculations. But then again it's all just theory.
Flywheel instead of battery storage?
"The solar constant at Earth's orbit in space varies between 1.412 kW/m² in early January to 1.321 kW/m² in early July. The top of the atmosphere averages 400w/m² between the tropics. At 28 degrees south latitude (Northern Cape) it is 380w/m² at the top of the atmosphere. 380*24*365 = 3328.8kwh/m². Add in an atmosphere and some very occasional cloud cover and 2300 is not a big ask."
That was a nice copy paste maybe but meaningless in terms that are used -
Your last try is a lot more "real world".[SIGPIC][/SIGPIC]Comment
Good luck.Comment
But won't the smart grid switch off loads when the wind stops and prevent a grid crash ?Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
On the flywheel breakthrough front, I've been tracking this company started by an individual named Bill Gray:
Here's the kickstarter that funded his magnetic bearing effort last year. Some good videos there:
If not Bill, then somebody else. It's only a matter of time before somebody brings inexpensive flywheel technology on line.
Mod note - 1) kickstarter links not allowed - most are huckester stuff and con men or just useless.
2) Links to your site are not allowed without prior permission from user name Jason.
For the flywheels - let just one person make one work then maybe there will be interest - just saying "trust me" like the last guy insisted is not good enough.
Flywheel tech is not at all new.4KW system featuring Suniva OPT265/Enphase M215Comment
Sorry about that. The kickstarter was funded last year. The primary reason I posted the link was because there are some good videos of the flywheel technology being used on it that don't exist on the primary site. What's new about this particular iteration is the harmonic cancellation technology that greatly reduces the accuracy required to spin up a 750 lb flywheel. Less accuracy = less expensive in my book.4KW system featuring Suniva OPT265/Enphase M215Comment
I bet they avoid testing them above ground ever again.Comment
This happened today a couple buildings away from where I work; the whole area felt it.
http://www.utsandiego.com/news/2015/...storage-poway/
I would say what they are doing is on the bleeding edge of technology, not the cutting edge!SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
