Oh but I did. That is where you are loosing your argument and showing your ignorance.
In any battery system you size the batteries to have a given about of Autonomy or days to cover your arse for rainy days. In this example was 2.5 days for each battery tech making them equal in every way. The FLA has to be about 15% larger than lithium. Reason is FLA operates from 100% SOC down to 50% or 50% of its capacity is usable for normal operation. In emergency FLA can go down to 0% SOC where Lithium is a brick at 0% SOC. In a Lithium chemistry they operate at 80% SOC down to 20% SOC or 60% of their rated capacity. That means they can be slightly smaller than FLA. In FLA you use no more than 20% per day, and Lithium no more than 25% which is th emodel I used.
So try again because you do not know what you are talking about. What IEEE Board do you sit on and co write for batteries?
