In original questions there were many loaded sublets of topics. In order to answer those, one must separate the issues.
1. Boat or Vehicle. Boat often more than 24V power rail and to charge or use Li batteries at the boat might not be possible as most of Li battery packs are so called 12V
2. Usage. Most of declared usage is impossible for Li packs, unless they are 150Ah or more. Problem comes from maximum discharge currents at the battery management side.
3. Charging. Most of battery packs can not allow fast charge. This might be a problem if you need to charge them fast.
My advice to be very careful with switching over to Li batteries. Many aspects of your usage have to be analyzed before you jump in to Li battery usage. Also there are so many different models, which are pronounced as "Li battery" but they are totally different from each other.
