I have 2 Grape Solar 12 volt panels wired in series to a Morningstar mppt controller. I have a 12 volt battery bank. How do I configure the controller?
configure Morningstar mppt 45 controller - 24 volt panels to 12 volt battery bank
What is the Voc spec for the Controller you have ? Morningstar has many MPPT controllers varying from 50-600V input limitPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Easy wire the panels in series. Just be sure to connect the battery to the controller first before panels as that will set the controller for 12 volts.MSEE, PEComment
2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
Why would anyone read the manual or directions? That would just confuse them.The ts mppt45 controller has an auto system voltage setting, OR, manual voltage settings(see page 20). You really need to set up the controller correctly before connecting it. There are a number of settings for various charging voltage setpoints, battery types, etc. Here's the manual,
http://africanenergy.com/new/wp-cont...ish-manual.pdf
MSEE, PEComment
Yea, that's like admitting defeat. Sort of like asking for directions from a stranger when you're lost. How humiliating.
An alternate: have a women read the manual and spoon feed the answer to the problem - they seem to do better at such tasks than most men. SWMBO helps me like that all the time.Comment
[QUOTE=J.P.M.;n380507]
GPS has largely eliminated the, lost and need directions problem, as long as you know how to operate your GPS. I have a few myself. Magellan seems pretty straightforward. I have a Tom Tom for Baja. It is not as user friendly.
