Sensij i looked at the 4210.would positive ground be a problem on a rv? What about the 8215 negative ground 150 volt?
Need advice on rv set up
Yeah, if your battery negative is grounded to the chassis, the positive ground CC probably isn't the best choice. The 4215BN is slightly more expensive, but should be a better fit. The 150 V won't help much with your current design, but if you ever move up from a 12 V system to 24 V, you'll have the ability to get more PV in the system without increasing amps (wire size) or number of parallel strings (requiring overcurrent protection).CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
Not any harder on it than running at 520 W. The charge controller adjusts the PV voltage away from Vmp if necessary so the array only ever produces 520 W. The extra energy is just sunlight on your array that is not converted to electricity... it is *not* burned up as heat at the controller.
Given how rarely a 600 W system would ever produce more than 520 W in real world conditions, the amount "lost" to clipping is insignificant in every possible way.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
I've been reading on it and it's set for agm need the meter to set for lead acid around $220 for cc and meter and 2 more panels 250. $470 Would this set up double my daily out put from 400 watts on pwm? If so just in winter or how much would I gain in summer months..I could double my watts with pwm for about $540Comment
Thanks so much for helping. I can't afford to keep blindly throwing money into solar with no knowledge. Alot of solar systems are for hobbies. Mine is my way of living. Wow 15% increase on my old panels by summer they degrad that much the first year? My fute plans are building a cabin on grid with solar assistance on 24 volt. With one of mikes cc. Question is my panels are renogy mono 22.5 18.9 volt. 5.75 5.29 amp. Could I on mppt combine 4 poly 22.4 17.8. 5.92 5.62. If so what would be my loses by not having the same panels. I can get these new for 75 eachComment
What are the pros and cons to use 2 of the same pwm controllers on two arrays using identical panels?Comment
You can only use one controller per panel array.
You can use several chargers on one battery
You should NOT use more than one controller per array, they will fight each other for control of the array, and your harvest will loose
Can you run one array on pwm and one on mppt. On mppt would all panels need to be the same imp and voc.Comment
As I understand it, your best design at this point is to buy 200 W more and the 4125bn mppt controller. You will be fine with teh 8 AWG you are already using. Buying 400 W plus a PWM controller is about the same cost for equipment, but because you have such a long run, the wiring cost / losses really tip the scale.
Are there other factors to consider that you haven't brought up yet?CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
Think that pretty much covers it 4125 bn 2 more panels then when I get my cabin on grid I can use it on 24 volt by wiring my batteries in series.Comment
