Usage 1200 watt hrs daily 400 watts pv on pmw 3.8 dec sun hrs. 416 amp hr battery. How many watts do i need for pwm vs mppt.
Announcement
No announcement yet.
Need advice on rv set up
I will let you figure it out.
Panel Watts for MPPT = [Daily Watt Hours x 1.5] / Sun Hours.
Panel Watts for PWM = Daily Watt Hours x 2] / Sun Hours.
Lets do PWM together and you can do MPPT on your own and never have to ask again.
1200 x 2 / 3.8 = 685 watts, round up to 700 watts with PWM
MPPT = ??? The answer is hidden below in GREAT BIG BOLD 36 FONT. See if you can find it.
500 WATTSLast edited by Sunking; 12-03-2017, 09:06 PM.MSEE, PE -
Easy enough. so 3 more panels and a tristar 60 pwm $600 or 1 panel and 45 amp mppt $600. on a 75 foot run that a no brainer. Thanks sun kingComment
Originally posted by Ho jo View PostEasy enough. so 3 more panels and a tristar 60 pwm $600 or 1 panel and 45 amp mppt $600. on a 75 foot run that a no brainer. Thanks sun king
PS -I'm biased, I own 2 of the MPPT 60A tristars
Mike where I'm at you can't get an address without first putting in a 25000 septic system so meter it is. Sun king has been of help to me. Maybe his people skills are a little rough.Comment
Where I'm at you can't get an address with out first getting a 25000 septic. Hard to get wifi so meter it is.60 amp would give me room to growComment
For monitoring,
You don't "get" wi-fi, you buy a $40 router and make your own wi-fiPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Originally posted by Mike90250 View PostFor monitoring,
You don't "get" wi-fi, you buy a $40 router and make your own wi-fi2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
Oh I see you don't need Internet just the router. And how many watt hrs for the router. Don't even have cell phone service unless you go 2 miles awayComment
I'm just trying to get through winter while saving all I can for utilities. Hopefully I can get on grid before next winter. Question is whether I could stack 2 renogy wanderer 30 amp 300 watts on each and cut back to 1100 watt hrs couple hrs less tv?Comment
A wi-Fi router, to provide data from your controller to any web browser (iPhone, Android, laptop, desktop) would draw about 5 watts. You could turn it on once a day, get the battery charge readings, and turn it off..
The LIVE view gives current PV volts & amps, and battery charge V & A and wattage
Here's a sample of the daily report
TristarLog_Dec3.pngPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Originally posted by Ho jo View PostI'm just trying to get through winter while saving all I can for utilities. Hopefully I can get on grid before next winter. Question is whether I could stack 2 renogy wanderer 30 amp 300 watts on each and cut back to 1100 watt hrs couple hrs less tv?
In winter, when it is cold out, the difference in performance between a PWM and MPPT CC will be significant. The real world Vmp could very well be *higher* than the Vmp at STC listed on the PV panel datasheet, and the PWM will be only operating the PV system at slightly over battery voltage. You could be looking at a 40% difference in energy produced between the two.
On a budget, the Tracer 4210A would be a fairly significant upgrade over the PWM controller you are using now, for $150.
With that controller, and 100 V max input, the 100 W panels could be safely wired into 3 panel strings. So, 600 W, consisting of two strings in parallel. Two more 100 W panels should cost something like $200-$250.
The controller would self limit to 40 A max output in the middle of clear, cold, sunny days, but otherwise would be providing *much* more charging power than you are getting now. 40 A output, if the panels are oriented optimally enough to achieve it, is ok for the 416 Ah battery.
CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
