Ok, now that we got the pissing matches out of the way lets get back to the topic, as I have an Update with some specs from the fridge. :P
Here are the specs for my panels again, with some other details I got off the spec sheets, as well as data I collected so far off monitoring that fridge.
Solar Panels: 320 Watt, 72 Cell Panels
Positive power tolerance from 0-5 W
Nominal Max. Power (Pmax) 320 W
Opt. Operating Voltage (Vmp) 37.1 V
Opt. Operating Current (Imp) 8.63 A
Open Circuit Voltage (Voc) 45.08 V
Short Circuit Current (Isc) 9.10 A
Module Efficiency 16.5 %
Max. System Voltage 1000 V (IEC) or 1000 V (UL)
Max. Series Fuse Rating 15 A
Power Tolerance 0 - + 5 W
FRIDGE DATA:
I started my testing with the fridge warm with nothing in it to start up, I then loaded the fridge with all different drinks, packed it right full as it will be that way once we go camping. My test results were any different after resetting the test 5 hours later with a cool fridge and cold drinks. I was opening the door on the fridge every so often as well. Here are the numbers
In 7.5 hours I used 0.367 KWH, 122.2 Volts plugged in, 0.68 Amps, 58-46 watts ( When it kicks on, then lowers slowly to run around 46 watts on the lowest. The fridge isn't on often from what I hear either, It has 5 power settings and just through testing I've been running it on 4 to get stuff really cold to see how much it actually pulls. Lowest wattage recorded is 1.1 watts, the highest spike is 748.3 watts.
So from what I get from this so far is that the fridge will spike under 800 watts to kick on, but during operating it is under 60 watts, as low as 46 watts.
FRIDGE DATA:
