Stumped
  • Rich Hargis
    • Apr 2017
    Stumped
    I recently purchased a 2009 Raptor toy hauler and it is equipped with a solar panel system. I discovered that the control box is fried. For the life of me I can not find any info on it. I would like to find another control unit just like it.
    All it says is" Phono Solar" along the bottom and "Solar Charger Controller" on the upper face. Any ideas?
    It's toast, and you may as well buy a new , quality unit, maybe Morningstar or Tracer. Tell us more about the voltage coming from the solar panels - 25V, 45V ??
    How many panels / watts . I assume you are charging 12V batteries ?
    • Rich Hargis
      • Apr 2017
      I have no idea, I will check the voltage tomorrow. You are correct about charging the batteries.
      • littleharbor
        • Jan 2016
        • 1998
        Charge controllers are inexpensive for basic PWM types. This should be a simple swap. Do you know what you have for solar panels on the Raptor? If you have a single panel, poly or monocrystalline, which is , say 26" x 58" or less (150 watts or less) you would be safe with a 10 amp or higher controller. I would go with at least 20 amps though so you have room for expansion. I checked the internet for your controller with no luck. This is probably a rebranded controller although it doesn't look familiar to any of the controllers I have seen in my experience.
        If you do the swap be sure to cover your solar panel(s) and disconnect your battery before you do anything else. When reconnecting always connect your battery first, then your panel(s)
