Chicken coop in remote area. No electric. But I need electric fence due to predators. Planned Consumption is below, with sources
I won't run fans when I need the water heater. And I won't run water heater when I need fans. But I put it all in anyway.
I planned on getting the following to run this stuff:
1. TWO 165AH 6-VOLT DEEP CYCLE BATTERIES - wired for 12v. (Sam's Club has them for about $100 each)
2. One 160 watt solar panel (12volt)
3, One 30AMP MPPT charge controller
4. A cheap 4 port fuse box wired into the MPPT load terminals. Bulbs, Fence Charger, Water Heater and Fan would be wired into the fuse box.
Does this seem right? I followed instructions commonly found on the web. But after reading this site (especially that Sun King guy), I am thinking that I had better run it by you folks. Scared. Haha.
Jimmy!
QTY | DESC | Hours Used | Watts | Total Watts | Watt Hours |
2 | LED Bulbs | 6 | 14.5 | 29 | 174 |
1 | Fence Charger | 24 | 20 | 20 | 480 |
1 | Water Heater | 4 | 60 | 60 | 240 |
2 | Fans | 8 | 4 | 8 | 64 |
Total Watt Hours | |||||
958 | |||||
System Voltage | 12 | Total Amp Hours | 80 | ||
Battery Discharge % | 80.00% | ||||
Battery Size (AH) | 100 |
Sources | ||||||||||||||||
60 Watt Water Heating Element 12-volt | http://www.ebay.com/itm/12-volt-60-w...-/272035903810 | |||||||||||||||
LED Bulbs | http://www.homedepot.com/p/Philips-1...1961/206923033 | |||||||||||||||
Fence Charger | https://www.walmart.com/ip/Parmak-MA...21798575#about | |||||||||||||||
Fan | https://www.amazon.com/dp/B01GPE7HYQ?psc=1 |
Jimmy!
