Let's say I was hoping to draw an average of 250 watts per hour during an 8 hour period. How many 6v golf cart batteries would I need for this, or is it impractical, period?
Help in figuring storage capacity needed.
Use the system sizing spreadsheet programs linked in several of the sticky threads in the Off Grid topic area of the Forum.SunnyBoy 3000 US, 18 BP Solar 175B panels. -
250W x 8 hours = 2064 watt hours
6v x 200ah = 1200 watt hours in a golf cart battery, so to keep drain to less than 50%. you need 4 batteries, I'd wire them into a 24V configuration.
This will be working the batteries pretty hard, nearly a 50% discharge, but you should get 2 years (700 cycles) out of them
Mike, I bought 6 100 watt Renogy monocrystaline panels. I was going to pick up two more batteries (have 4, going with 6), and with a timer, I've found a way to reduce the draw below 1800 watt hours. Since my panels are 12v, should I just wire these up as 12 volts? Not sure why you would go with 24. Thanks.Comment
24 volts allows you to wire all batteries in series and that also saves needing an expensive solar combiner box for 12V operationPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Mike, I'm not sure what you mean by a solar combiner box? My setup is the panels, an mppt controller, the batteries and a charger/inverter (bigger than I really need, for sure). I've also got a renogy tracer meter to monitor the charge on the batteries. So I'll have 6 panels, 6 batteries and two ways to charge the batteries, either solar or my generator.Comment
The combiner box is an electrical box with a fuse or circuit breaker for each PV panel. Two parallel strings of PV are OK, but more than 2 and you need a combiner box for safetyPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
