Help in figuring storage capacity needed.
  • medic5678
    • Oct 2014
    • 16
    Let's say I was hoping to draw an average of 250 watts per hour during an 8 hour period. How many 6v golf cart batteries would I need for this, or is it impractical, period?
    Use the system sizing spreadsheet programs linked in several of the sticky threads in the Off Grid topic area of the Forum.
      250W x 8 hours = 2064 watt hours
      6v x 200ah = 1200 watt hours in a golf cart battery, so to keep drain to less than 50%. you need 4 batteries, I'd wire them into a 24V configuration.
      This will be working the batteries pretty hard, nearly a 50% discharge, but you should get 2 years (700 cycles) out of them
      • medic5678
        • Oct 2014
        • 16
        Mike, I bought 6 100 watt Renogy monocrystaline panels. I was going to pick up two more batteries (have 4, going with 6), and with a timer, I've found a way to reduce the draw below 1800 watt hours. Since my panels are 12v, should I just wire these up as 12 volts? Not sure why you would go with 24. Thanks.
          24 volts allows you to wire all batteries in series and that also saves needing an expensive solar combiner box for 12V operation
          • medic5678
            • Oct 2014
            • 16
            Mike, I'm not sure what you mean by a solar combiner box? My setup is the panels, an mppt controller, the batteries and a charger/inverter (bigger than I really need, for sure). I've also got a renogy tracer meter to monitor the charge on the batteries. So I'll have 6 panels, 6 batteries and two ways to charge the batteries, either solar or my generator.
              The combiner box is an electrical box with a fuse or circuit breaker for each PV panel. Two parallel strings of PV are OK, but more than 2 and you need a combiner box for safety
