Need help with configuring RV solar setup
One thing that needs to be considered are the 12v systems of the RV. You will need either a second bank or a means of converting the 24v to 12v. Any method of doing this means losses not incurred while using a 12v battery to power the rig.
You must plan on running some stuff with that kind of wattage. we run 750w and 675 Ah of battery at 12v and average up too 200 Ah a day. The heavy days are when we use the little air conditioner for four or five hours pulling amps in the mid 30's. Luckily the A/C will run off of the panels mid day but it's only 5000 BTU. With 1300w you should be able to run one a few sizes larger. A mini split would be even better but we don't need it often enough to justify the expense. Outside of that the majority of the cooking is done on a hot plate, two or three pots of coffee come from the auto drip and the TV/Sat may run 12 hours a day keeping the dogs quiet. Eventually we will add a smaller residential fridge for longer trips and a heating element to the water heater.
On the inverter, last year we ran two inverters. A 3000w Ebay PSW that lasted a year until it showed its dislike of the start up surge of the air conditioner by becoming a useless brick. Since it took so much power at idle we ran a Powerbright 150w MSW inverter for the TV/Sat and phone charging. With that inverter everything they say about MSW was true. The chargers and satellite box ran HOT and the TV had vertical lines in it. So when the big inverter died I was on the hunt for two PSW units. I knew the smaller would be a Morningstar 300w fanless but dreaded picking out the big one. Someone told me to try out a Tripp-lite 1250fc that he had run for 5 years 24/7 for a residential fridge. he said that yes it's MSW but not all of those are created equal. The Tripp-lite is a industrial inverter made for heavy loads and will start your A/C without braking a sweat. He said it has a huge transformer for doing this and has a cleaner sine wave too. Well for $200 I gave it a shot. He was right, the compressor on the A/C starts so easy that you wouldn't know it was running until the cold air comes out if you are not looking at a kill a watt. The phone chargers and satellite dish run no warmer than at home and the TV picture is brilliant. They do make a 2400w 24v unit too.
I look forward to seeing what you want out of your system and how it works out.
It is an excellent price on Amazon.Comment
Regarding the Tripp-Lite-PV1250FC, I could not find online how much power this draws with no load (self-use) or the efficiency. I am evaluating this to power a refrigerator from batteries. However, if this non-sine inverter could power/charge an APC UPS I might be able to make it my only inverter.
I am not saying the Tripp-Lite is poor quality. I saying I just can't find any specification about that unit with reference to a "No Load" amp draw.Comment
I also could not find any reference to a "No Load" Amp draw. Most quality inverters show something in the 0.X amps DC for no load. Others just provide an amp rating but don't tell you if it is DC or AC. Still others don't tell you anything.
No load - 2.2A at 12V DCUtilize you vehicle's battery to efficiently power work site power tools, pumps, as well as your laptop computer. Continuously supplies 1250 watts of 120VAC power to (2) AC outlets from any 12VDC battery source. Frequency control locks AC output at 60Hz for operating stability of motor loads and other inductive loads with high current startup requirements.NOTE: To protect against high current draw that may occur during inverter failure, a fuse link rated at 200a should be positioned no more than 18MSEE, PEComment
12 Volts DUH
Guys the problem you are going to run into is just about all 12 volt Inverters, especially those found in box stores and brands like Stanley, Black n Decker, Energizer.... are pretty cheaply made MSW Inverters intended to be used in a vehicle with the motor running and alternator carrying the load. Put it to you another way. If your Inverter has standard 120 Volt Receptacles for you to plug into, you have a mobile, and if it cost less than $1/watt, it is just bare minimum electronics to make a MSW Inverter. Its a Toy. You can find some decent Inverters made for Marine and RV. But expect to pay $1/watt for good TSW units with good efficiency. Most of the stuff out there is junk and very inefficient.MSEE, PEComment
Thanks Sunking. I was digging up the manual and that's not listed in there. I don't know of the other models but the 1250fc has a load sense that will turn off the inverter when it's not needed.
I didn't go 24v because dual banks or a transform is more headaches. Plus while 24v is more efficient for bigger loads, our biggest load is the microwave pulling 1375w. Everything else is 900w or less.Comment
!!! I was on that page... They overloaded that column... You must be good at where's waldoComment
Nah, just experience with Tripp.Lite. They are popular with the Electronic Hobbyist and Students. Budget friendly slightly better than Box Store Stuff. Just about all Tripp.Lite Inverters in that power range will consume 2 to 3 amps collecting dust. Even if they do use low Stand-By power claimed efficiency is at Full Power. Many when operated at less than Full Power are 50% and less efficient. To get the really efficient stuff cost money and most of it is for 24 Volt and higher applications...................................... ................................... BOTTOM LINE IS THIS: If your Inverter requires more than 80 to 100 amps to operate at full Power....... You are operating at too dang low of a voltage and at high risk of FIRE. Very few people have the skills or knowledge to terminate anything larger, or even know if there was a problem until you see smoke and fire. Save yourself a serious chunk of coins and add safety my moving to higher voltages.MSEE, PEComment
Nah, just experience with Tripp.Lite. They are popular with the Electronic Hobbyist and Students. Budget friendly slightly better than Box Store Stuff. Just about all Tripp.Lite Inverters in that power range will consume 2 to 3 amps collecting dust. Even if they do use low Stand-By power claimed efficiency is at Full Power. Many when operated at less than Full Power are 50% and less efficient. To get the really efficient stuff cost money and most of it is for 24 Volt and higher applications...................................... ................................... BOTTOM LINE IS THIS: If your Inverter requires more than 80 to 100 amps to operate at full Power....... You are operating at too dang low of a voltage and at high risk of FIRE. Very few people have the skills or knowledge to terminate anything larger, or even know if there was a problem until you see smoke and fire. Save yourself a serious chunk of coins and add safety my moving to higher voltages.Comment
Took me 6 seconds http://www.tripplite.com/industrial-...lets~PV1250FC/Comment
No sir. Wiring and connections between Battery Term Post and Inverter input Terminals. Large Inverters can melt battery lead post, and a loose connection on a Battery Term Post will melt it under high current.MSEE, PEComment
I looked around for inverters and I guess Magnum Energy inverters are the best in the long term. Used ones are not so easily available so I guess I will have to go for something cheaper for immediate needs and then keep looking for a Magnasine.
Has any one had any experience with:
Specs look good but I am not expecting a top quality at that price.
HemantComment
MSEE, PEComment
It was a pain having to buy a 16 ton crimping tool but it sure makes short work out of the 1/0 lugs. Actually I ordered the 12 ton and got the 16 ton instead. those 240 mm dies are the size of my thumb. lolComment
