Could you explain to me what a shunt does . I found a curcuit breaker and they said the shunt went along side the breaker. Where does the shunt hook up to and what does it do.
Breakers and shunts
The SHUNT is a calibrated piece of wire, used to measure AMPS flowing through the circuit. The can get warm or even hot, I don't know that I'd park it next to a circuit breaker. The voltage across it (just a couple of millivolts) is used to calculate the amps flowing.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
You need a Ckt Bkr to protect your wires and prevent a fire.
Shunts for amps, are optional measurements.
Battery Temperature Sensor for your charge controller, should be present, to provide correct charge voltage for your battery.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I am buying a new Morningstar 60 AMP MPPT charge controler and a tempiture probe . It will be coming in December.
I need to put a fuse between the charge controler and the batteries. I already have one from the batteries to the inverter.
Thank youComment
Do you know your array size/wattage, and battery bank voltage? Just take your array watts, and divide by your battery bank voltage, and you will have MAX amps to size your fuse and wires to. This is a crude way, but likely within 10% of the "right" value.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
