Is it OK to use solid copper wire between panels and charge controller?
    • 15203
    #31
    Originally posted by Naptown
    57 in a couple of months
    My trek in life
    trade school to become an electrician
    electrician for 2 years moved from helper to estimator
    Electrical contractor sent me to school for HVAC.
    Left there went to work for AC contractor
    Tired of being laid off winters so went to college for Building construction
    built a couple hundred tract homes for a builder and got tired of mud.
    When mortgage rates hit the 13% mark I did some property management then did the solar thermal thing for Reynolds for a couple of years before it died out.
    Switched to remodeling (cleaner and less rain days) doing mostly high end kitchens and baths. (google Clive Christian kitchens and you will see some of the type of work I did) That stuff was extremely expensive and low quality and took a lot to get it to look like in the pictures.
    When things went south last time I sat around and came back to the solar business.
    At least you can claim you made it through life using "hands on" knowledge. I on the other hand (will be 60 in May) took the easy route and got an EE degree in the 70's. Spent too many years designing on paper not really understanding the real world of electrical power. It wasn't until the mid 80's that I got to experience real life being a Field Project Manger. (real fun being on the end of a rope doing a 500mcm cable pull). Then the real learning began.
    • FloridaSun
      • Dec 2012
      • 634
      #32
      damn... there's gotta be somebody around here older than me.
      • Naptown
        • 6880
        #33
        Maybe we should start a sub group call it the OFB
          Well not so sure I would say the Easy Route if you mean BSEE. ASEE is easier, but still requires a sharp cookie. With that said an EE is a non descriptive, like a Doctor. There are so many disciplines and specialties.
          Even a BSEE dunno chit when they graduate. They have only dipped their toe into electronics, electric power, communications, controls, etc. They specialize in nothing and really do not know much, and for some get quite frustrated once they realize the education process has only begun. However they have the tools and fundamentals. What I look for in c graduate candidate is have they taken EIT test and passed.Most electrical engineers never ever take the EIT and PE exam. Once you have the PE license in you chosen discipline opens the world up and is your Meal Ticket. Once you have it you can pretty much pick where you want to live and work, rather than go to where the work is.
            I will admit to 65, but not a bit more.
              68 - Still working - got recycled on a project in India working on gas consumption in direct reduced iron plants - back in India - again.
              I was quite happy playing until the company showed up asking for assistance - however, another year at the max.
              For now I ride my bicycle 20 miles and work out for about 1 1/2 hours a day.
                • 15203
                #37
                It was a BSEE majoring in solid state materials like the IC and CCD type chips. Actually I did a Senior Project and Science Paper on Cadmium Sulfide Solar Cells so I was sort of expose to PV Panels at a real early stage.
                Unfortunately (or fortunately depending on how you look at it) the Solid State industry took a nose dive in the mid 70's. So I went on to designing power distribution, lighting and controls for a Consulting Engineer. Expanded that into Energy Management and Programmable Logic Control design. Followed by Project Management. I had the chance to get my PE but then the job had me traveling a lot (80 hour weeks and missing many weekends and holidays) so it was something I let go. It has been an up and down ride across a half dozen different manufacturing companies but now I am back working for a Power Quality Engineering group. I figure a few more years at this but I want to get up to speed on the Solar side and will probably continue along that for a while until I just want to kick back and relax when I get to or past russ's age.
                • FloridaSun
                  • Dec 2012
                  • 634
                  #38
                  ... when I get to or past russ's age.
                  now that guy is really OLD!
                    68 years young - just got back from my 20 mile bike ride (actually 30.54 km) and as today is a holiday here I spent the day in my exercise mode.
                    • FloridaSun
                      • Dec 2012
                      • 634
                      #40
                      That's the way to go, Russ. Gotta keep moving, use it or lose it. Works the same way for the mind.... which is one reason I like this site. It keeps my mind well exercised.
                        • 5242
                        #41
                        year
                        I have a couple years on all of you. There were no cars built the year I was born. Bruce Roe
                          • 15203
                          #42
                          Welcome sir. I hope to live old enough when cars are no longer built.
                          • Naptown
                            • 6880
                            #43
                            '43 of '44
                              • 5242
                              #44
                              cars
                              '43 of '44
                              43. Seen a lot of advances in electronics since then, worked on some. Bruce
                                I seem to recall something called a "tube", I believe. And a thyratron for switching?
