Yeah, I am sure this is the issue. The work-arounds are not worth it, I will just leave it powered by the battery bank and manually reset it as needed.
Quick question though: Is it better to use the LOAD side of the CC for the actual load or just go from the battery directly (and fuse ofc). I was just thinking this because if my meter is between the CC and the battery than it is going to measure ALL the power going IN and OUT of the battery together. For example, if I did not use the CC LOAD output terminals, and I put another meter from the battery to the actual load I should be able to see what is going IN to the battery on one meter and all the consumption on the other. Perhaps then I could also add a better load disconnect ... this CC (Genasun 5V) doesn't disconnect until the battery is critical, like 10.4V or something ludicrous. I would prefer to have it cut out at like 50%, maybe 11.9V or so. Maybe something like this already exists on the market or can be easily built?
Thanks for your response.
