My daughter and I are building a project that consists of (15) 6volt 250mA panels. We are wiring these in series-parallel as (5) strings of (3) to get 18V nominal at about 1.25A to charge a 12V AGM battery. The individual strings will have schottky blocking diodes before being paralleled and all fed into 5A MPPT controller/charger (Genasun-GV5). We have 3 questions:
1) would bypass diodes be helpful (even remotely) across each 6V module? I have lots of 9A 45V Schottkys available so price is not a concern. But if one panel is bypassed, then the remaining 2 providing 12-14volts would be insufficient charging voltage and be way off from the other 4 strings of 18-21 volts. Or will it not help provide energy but only serve to protect any one cell from the other 2 dumping into it in a given string?
2) would minor voltage differentials present a problem between the strings if all are within a couple hundred millivolts of eachother, all ranging between 18-21, but balanced to be +/- .3V of one another? Is there a way to better balance them or combine them to negate this effect using just one MPPT controller?
3) some strings are SE and others are SW facing and this is unavoidable due to the strict location they must be placed, there is no South facing opportunity. Given this situation we can exploit the morning sun through a set of panels and the afternoon sun through another set. What is the best way to funnel this back into the same battery? Should we use the same charge controller? If so, even with blocking diodes, it is likely to mess up its MPPT tracking and see the lower voltage of both sets all the time. A second tracker is expensive unless it is PWM. But even then, will 2 controllers going to the same battery affect eachother? Or is there a better way overall to handle this that I am missing?
THANKS!!
THANKS!!
