Hi to All, my first post here .I have just found this forum ,been reading tru some topics and find it very informative.Ok now to get started... ,im planing to make a diy panel that will be used to power home aircon. unit , so ive been looking around for materials that i will need .So far i decided to use tempered glass i can find in local shops, aluminium frame for the panel/s i will hopefully make using L-profile alum.
Everything else has to be imported .Since this is the first(i hope not the last..) panel that im building ,i will try to keep the costs at minimum.
My power requirement is around 1kw ,i understand that i will need a power inverter too?
Which cells would you recommend ?
Tabbed or not?
which encapsulating method?
Diodes ,buss bars etc?
Panel placement ,ground or roof And so on..
All the suggestions and comments are welcomed !
Tabbed or not?
