I have built a two large solar panels that are producing 12 volts and 24 amps with that much power running into my battery bank do i need a voltage dump?
voltage dump
No. Only wind or hydro, that needs to keep a load to prevent freewheeling and excessive RPM's need a dump load.
Solar can be safely disconnected when the batteries are full. Usually a 3 stage charge controller (PWM or MPPT) will do this automatically for you.
Trying to manually use a voltmeter and disconnect batteries when you think they are full, will give disappointing results.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
