The frame size is 40 1/4" x 77". for 72- 6"x6" solar cells.12 rows of 6
i'm using 1/4 Tempered Glass
SYLGARD 184
6x6 solar cells .6v/ 8+a/ 17% eff.
I have been searching for the best diodes to use and how to wire the panel i think i figured it out, but just want a little Sign that its the best decision. i figured i would put one after every 2 strings of 6.
I just bought these diodes but i'm not sure,10pcs 8 AMP 45 VOLT Schottky BLOCKING DIODES Wind/Solar, i think i need to use ones that rate at a higher amp from what i have read.i know i can put in different ones even after i encapsulate but would rather do it right the first time.
Now in another thread i have seen this layout
i also had a question on the encapsulation part, i'm not sure if i will need 1 or 2 mixes to do this panel?
I have spent about $500 so far but if i don't have to use the 2nd silgar than it only cost $450 or so. kinda nice for this size unit. and i have been reconsidering putting a backing to the pannel like 1m
