I will go back to the first circuit and try to nut it out.
with the video, as the load increased the amps increases . on one gage it was about 6 amps the other about 4 amps, is one before the diode and the other after showing the power used by the diode?
sorry for some silly questions, circuit design was not part of appliance repairs, remove and replace is the norm.
from all the research i have been doing the reccomendation is for only 2 bypass diodes for a 36 cell panel protecting 18 cells each which would be easy to wire. do you agree that 3 is overboard?
if so i will make it with 2.
i have 5, 2 legged inline diodes, 3 from the new cells i purchased and 2 from an old panel. they are only 10 amp each, i might use them in the next panel
is there a way of joining them together to get 20amp or does it always halve the value irrelevant of the way you join them?
thanks again.
have not heard from longwolf for a while, how are your panels going? did you figure out the best arangement for your diode's and how is it working on the van?
thanks again.
