Diodes and bypass diodes
  • longwolf
    • May 2010
    • 121
    I've gotten my 6x6 cells. They came with tabbing and bus wire but no diodes.
    I'll be making 36 cell panels and they should be 144 Watts each.
    They'll be going on a van, so a couple bypass diodes sound like a good idea (you never know when you might be forced to park under something).
    But I haven't seen any real info on how to use the diodes.
    I've made a drawing of my best guess at how to do it.
    Do I have the right idea?
    Also, what type and size diodes would I need?
    Nope, those are series diodes. All current in your array must flow thru them, all the time. You will loose 1 volt for each diode you have drawn.
    Bypass diodes are normally reverse biased, and only get fwd biased when some cells are shaded.
    When a segment gets shaded, it goes to high resistance. The diode comes into play, and allows the power (reduced) to continue to flow
    • longwolf
      • May 2010
      • 121
      Ok, so would this be the way? Two bypass and one blocking.
        Almost. The bypass need to cover the entire panel, as you've drawn it, if either end gets shaded, the whole panel will be shut down.
        If you are going to use a charge controller, leave out the blocking diode, as modern controllers perform that function for you.
        Amp of your bypass diodes should be 2x your panel max amps. (4 amp panel needs 8A diode, and heat sink, as all amps will flow thru diode and heat it up.) Try to use Schottky diodes, they have lower voltage loss. Diode voltage should be 1.5x your entire array Voc.
        Also, try drawing it like a multi cell battery, and visualize 1 cell going bad, and how the power will flow around it, and what the voltage loss would be. Currently, with only 2 diodes, you will loose 50% of panel voltage, if shadow appears.
        What do you use for your drawing program? Nice.
        • longwolf
          • May 2010
          • 121
          Ouch, not good. These will be going on a platform I made under my van's ladder rack. I occasionally do carry ladders and/or lumber up there. Also the ladder rack's own up-rights will cast shadows.
          For now, I'll only be using a cheap controller (all I can afford) with one panel . Latter I'll put the other two panels together and try for a mppt controller.
          The cells are rated at 0.5 volt/ 8amps and I'll be making 18 volt panels. Once I have all three panels, they will be in parallel. So that means the bypass diodes must handle at least 16 amps at 27 volts?
          Looking at eBay, the only ones I see in that range are the square, 3 pronged type. Will those work?
          I'm still not getting it.
          If I were to use 8 diodes, the way I added the two, that should work shouldn't it?
          Other than the price of the diodes, would there be any other downsides?
          Thx, it's an old copy of Jasc Paint shop Pro v7.01
          If you like those simple drawings, you should see some of the things I've done with TrueSpace, a free 3D program
            8A panels
            Those will need at least 12a diodes, larger if you can find them. This is why modern PV's are going to higher voltages, at the current density of 8 amps, your feed wires/tap/ribbon has to be large enough to carry 8A, and it begins to shade the cells underneath. Have you followed some of the other threads here about volts vs amps still gets you the same watts,
            If you are a homeowner who is about to put a solar panel system on your home or you are a newbie to the solar market, get started here! A non-technical forum to help you understand the in's and out's of solar.
            Each time you double the voltage, you improve the efficiency 400% for a given wire
            Bypass diodes only need to handle their own panel's amps, not the whole array.
            But if you are planning on putting them in series, your 25V OC panels, that jumps to 50V, and you should use 60-80V diodes.
            Any shade is bad. If you are leaving a ladder up, then just use a worm drive saw and slice off the bottom (shaded portion) of your array. It will then work the same as if it was shaded. Poorly.
            • longwolf
              • May 2010
              • 121
              I was an electrician and have a good handle on amps/volts/watts/ohms/parallel/series, wire sizing, etc
              I won't be leaving a ladder up there. But I am living out of my van and doing handyman work when I can find it. My biggest needs are running my laptop (to help find work) and to run fans (too hot here to sleep without them).
              I've already killed one set of batteries (the van's a diesel and uses two) so the first panel is a priority!
              Later, there are other devices I'll be using, up to 500 watts.
              It may be a while before I can afford an mppt, so I'm trying to keep the voltage low.
              Anyway, would this config work?
              what are the downsides?
                You have to re-draw it as a stack of batteries, with the diodes. The pictorial view, while nifty is confusing because the whole thing is shorted with traces going side to side.
                + --[ |-- - one cell
                + --[ |----[ |----[ |----[ |----[ |----[ |----[ |----[ |----[ |----[ |-- - stack of cells
                • longwolf
                  • May 2010
                  • 121
                  Here's an attempt to do it as batteries in a strait line.
                  Each four cell, horizontal row is replaced by one battery.
                  The 1st image would show the circuit as it would be in the image from my previous post.
                  But I suspect the correct way would be shown in the second image I'm uploading.
                    Great, the 2nd one is the better one. So, each PV cell, is .5V. A diode needs 1 volt to energize. And you won't need a zillion diodes. So about every 2.5V of PV, bypass that, with a diode. If your panel goes into bypass, the first step down from 18V would be 15.5 which is the bare minimum to charge a battery with. It's sort of why a "12V" panel produces power at 18V and measures 24V no load. And it's easier with a larger array, in series, then if you had a 40V array powering a 24v bank, and some shade came along, you still can keep charging
                    • longwolf
                      • May 2010
                      • 121
                      All right!
                      Thx again Mike.
                      And, because I know you like them, here's a pictorial view of the solution.
                      • crxvfr
                        • Jun 2010
                        • 173
                        Something that's different about this board that I like sometimes is the way they don't give you an answer. I work in the motorcycle industry. If you ask a question on a motorcycle forum, you'll get tons of answers, and you have to figure out which one is the best. Here, they tend to make you show your work. Some people get completely turned off by that notion but I kind of like it, sometimes.
                        Longwolf asks a question. Mike pretty much says no, take another guess.
                        ...and he does. Eventually the problem is resolved and the work is there to show for it, ...so when shleps like me happen along this thread, I can follow the same, learning why and why not. The more I do this, the more I find out how much Mike knows about solar panels and stuff.
                        Ya got yerself a stocker Lonewolf. Ha, that sounds so western.
                        I've been reading the encapsulating thread you started in the other area, with interest.
                        I'm going to be doing the same thing, kinda, but I'm a hillbilly.
                        I want to try to make three 4x5 320 watt panels.
                          Originally posted by longwolf
                          All right!
                          Thx again Mike.
                          Sorry about the delay. that pictorial, it's not good, try a plain schematic, and go over it yourself, count up the volts as you go, 0V at the ground terminal, 6 series cells should be close to 3v (.5V per cell), and so on to your most positive point. then about every 2.5v, you could place a bypass diode.
                          • longwolf
                            • May 2010
                            • 121
                            .... that pictorial, it's not good,...
                            Sorry Mike, you lost me again.
                            The pictorial view is essentially the same as the second schematic image from 9th post in this thread.
                            The new pic shows a bypass diode every 2 volts/ four cells.
                            Maybe you're misreading the image. It shows thirty-six 6x6 cells. Four per row with nine rows.
                            The gray lines represent the two tabbing wires across each cell and going to the buses on each side of the panel.
                            I'd sure hate to give up on you and disappoint crxvfr
                              Yeah, the pictorial is not good, the gray wire shorts all the cells out. Tab wire goes from topside, to bottom side, not across the whole row.
