The maximum power horses !
    Originally posted by stubbyboy
    so your saying it cant be done ?
    I am saying I do not believe one word of what you said.
      A 60 HP pump is quite an awesome beast. There are not likely very many of them around. The power required to run it would be at least 50KW. So, it's a bold claim, and we often hear tall tails here, so a photo, or site details would give your statement some credence.
        • 5199
        #33
        i currently run a 60 hp water pump using solar dc no inverter or mppt works great so far
        And I want to see how you manage without MPPT. Bruce Roe
          And if he replies that he is using a linear current booster, that is basically a very specialized form of MPPT.
            When was the last time you ever seen or heard of a 50 to 70 Kw booster?
              Obviously it was custom built by the guy next door.
              • zohaib
                • 37
                #37
                How much 5 Hp DC motor give flow of water in gallons per minute
                i want to pump water from 100 feet.Which DC motor would be feasible?
                  #38
                  Grundfos makes DC well pumps that work quite well with solar.
                  What is more important is how much pump do you need.
                  What are the minimum daily or hourly gallon or liter requirements?
                  What is the size of the well casing.
                  You are in Israel If I read your other post correctly So I would imagine pretty sunny.
                  • zohaib
                    • 37
                    #39
                    Here is my requirement for solar power pump system
                    I am from pakistan and want to install this sysyem in villages. My requirement is to use 5HP DC motor along with 5kw panels. I want to pump water from 100 feet and minimum daily requirement is 0.5 cusecs and want to use this system 5-6 hours per days.
                    Kindly guide me about this.
                    Thanx
