MPPT buck converter that isn't optimized for battery recharging?
  • fufuValve
    • Jan 2018
    I am looking for something similar myself a MPPT Buck/Boost Charger with variable output for charging Lithium Manganese Oxide (LiMn2O4) That is not tied to specific cell voltage like lead acid or LiFePO4.
    I have an unusual setup using Nissan Leaf batteries which are 3.8v nominal per cell
    Per Cell 2 x Cells 3 x Cells 4 x Cells 5 cells 6 cells
    Ideal Charge Min 4.1 8.2 12.3 16.4 20.5 24.6
    Ideal Charge Max 4.15 8.3 12.45 16.6 20.75 24.9
    Charge Max 4.2 8.4 12.6 16.8 21 25.2
    Nominal 3.8 7.6 11.4 15.2 19 22.8
    Lithium Iron Phosphate (LiFePO4)
    Ideal Charge Min 3.5 7 10.5 14 17.5 21
    Ideal Charge Max 3.65 7.3 10.95 14.6 18.25 21.9
    Nominal 3.2 6.4 9.6 12.8 16 19.2
    Lead acid
    Ideal Charge Min 2.3 4.6 6.9 9.2 11.5 13.8
    Ideal Charge Max 2.45 4.9 7.35 9.8 12.25 14.7
    Nominal 2 4 6 8 10 12
    I found this on Ali-express what do you guys think? My Chinglish is average
    (YF-BKT80V15A) Non isolated four switch synchronisation buck-boost MPPT https://tinyurl.com/yd6adcmr
      That's the miracle of Chinglish. It can mean anything ! Try it and see.
      I'm not sure I can agree with your statement of
      > LiMn2O4 That is not tied to specific cell voltage like lead acid or LiFePO4.
      All batteries have a specific cell voltage at full charge. Exceed that, and you get a surprise fire_1f525.png
      Figure 1 shows the voltage and current signature as lithium-ion passes through the stages for constant current and topping charge. Figure 1: Charge stages…
