Efficiency of a horizontally mounted panel?
  • Stevet47
    • 5
    I have a unique application that may lend it self to use panels in a flat orientation. I have looked at all of the tilt angle calculators, etc that I can find, but have not been able to locate anything that will tell me my performance loss at a desired angle.
    For example, I know I need a single 180W panel mounted at 37 degrees true south for my system. If I mount the panel at 0 degrees, obviously I will loose significant efficiency, but just how much? I need to determine the required wattage of an array at 0 degrees to equal 180W at 37 degrees.
    How do I go about doing this?
  • Naptown
    • 6880
    At 0 deg do you mean horizontal or vertical?
    mounting horizontal you will be cleaning the panel a lot. The output will be very high in summer and very low in winter. Vertically the opposite will happen.
    I don't like to lay the panels at less than 10 degrees.
    • Wy_White_Wolf
      • Oct 2011
      • 1179
      Use PVwatts.
      First run it with the panel set for ideal angle no DC to AC derate. Then run again with angle set at 0. Divide the former into the latter for %.
      WWW
      • Stevet47
        • 5
        Naptown, I mean horizontal.
        Wy_White_Wolf, thanks for the link. I am not quite sure I understand what that is doing, but I think I got the results I need. Does this make sense to you:
        I entered a DC Rating of .18Kw because I have a single 180w panel.
        AC to DC Derate: 0
        Array Type: Fixed Tilt
        Array Tilt: 37 degrees (based on http://www.macslab.com/optsolar.html at fixed tilt)
        Array Azimuth: 180 degrees (south)
        And came up with: 4.26 yearly solar radiation.
        Then I repeated for horizontal panel:
        The only thing I changed was Array Tilt: 0 degrees
        And came up with:3.78 yearly solar radiation.
        4.26 / 3.78 = 1.12 or 112%. So that means I need 112% more wattage, or 201.6 watts?
        Does that math seem correct?
        Thanks!
        • Naptown
          • 6880
          What is the intended season or seasons you plan to use this what you got was the average annual insolation.
          • Stevet47
            • 5
            It will be used at a cabin only occupied June - August.
            Insolation is:
            Jan: 1.45
            Feb: 2.36
            March: 3.32
            April: 4.29
            May: 5.03
            June: 5.60
            July: 5.61
            August: 4.88
            Sept: 3.68
            Oct: 2.37
            Nov: 1.48
            Dec: 1.21
            • Wy_White_Wolf
              • Oct 2011
              • 1179
              AC to DC Derate: 0
              Thanks!
              Run that for the months you will be there (June, July, Aug) and use the worse case.
              WWW
