I'm looking to do an independent study class and am planning on building 3 solar panels and testing them. My big problem is what sort of test I should run. What kinds of small-scale experiments could I potentially run with my 3 panels?
Experiments with Solar
Gear you need
Clip-On DC ammeter
DC voltmeter
MPPT charge controller: Morningstar Sunsaver MPPT (new, very efficient controller)
{If you don't use a MPPT controller, your tests will be erroneous.}
30A DC load (mod-sine 300W inverter and 3, 75W light bulbs)
12V Battery
Ambient air thermometer
IR thermometer (to measure panel temp)
Tests to run:
Initial power output (15 minutes before solar noon, panels must be hot from sun)
Test each panel 3 times (rotate testing, 1,2,3 back to 1,2,3, 1,2,3)
Record voltage, Panel amps, CC amps for each panel, while load is on (a full battery will not absorb any PV power)
average results of each panel
Leave panels sit out in weather for a month
redo the noontime test. Beware of different months, that may have different Solar
Isolation. That would skew the results.
Results should be interesting.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
