Advice on cleaning PV panels
Unless you wash your panels at night without lights, then there is gonna be voltage in the arrays which might be dangeous (especially the DC). No, I have not measure the voltage at night, but it shouldn't any voltage during night time if any. I have water in J Box and I email my installer during weekend and it got taking care first thing Monday.(they knew that is dangeous) Anything you do in life involves with different level of dangerness, then you assume your own risk.Does that mean there is no danger? Or, that there is no time when there is less danger?
I can look out the window and tell when the system is producing 7000 watts or 20 watts.
I have actually gone out and measured voltages at night, seeing less than 10 volts,
have you? Bruce RoeComment
And did you notice that it is always the windshield.Over the years, I've seen many cars with a single stress crack across the windshield. one out of 10,000 maybe. It does not happen often, but why invite it happening at all? Early morning, with dew still on the panels, the crud is soft and washes off easily. I have pond water, no mineral content, and so here I can skip the DI rinse. While in Los Angeles, I had to use the DI rinse.
The windshield in a car is made of 2 layers of glass with a plastic sheet in between.
So a windshield can not really be compared with an solar panel.
A solar panel has a tempered glass last time I checked.Comment
I have measured the voltage under a full moon and clear sky; it was less than 10V for
a 350V array. You will need a heck of a light to produce much voltage, and then it will
probably only hit one panel which here could only do 37 Voc. Bruce RoeComment
Well, have fun and let us know if there are any failures. All we can do is give advice on what we know.
Tempered glass is very strong, but also very brittle, and if a crack starts, it nearly instantly converts all the glass to marble size fragments.
Windshield glass is also very strong, heat molded to a curve, and plastic bonded to another sheet of glass for even more strength, but it is NOT tempered. Most of the side and rear windows are tempered, and not heated as much as the windshield is. I'll
wash my panels to avoid thermal stress and now you have told us how you want to wash yours. Fair enough.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
This thread prompted me to see if LG had any advice for my LG305N1C-B3 panels; from the online installation manual:
Life's Good with LG. Shop online at LG.com US to find exclusive deals on the latest home entertainment and appliances. Add smart technology and modern design to your home today.
After Installation
• Removal of dirt from the front glass can increase
output.
• Water, ethanol or a conventional glass cleanser
with a micro-fiber cloth can be used for regular
washing or rinsing of the front glass to remove
dust, dirt or other deposits.
• Aggressive and abrasive cleansers or chemicals
such as alkali chemicals including ammonia based
solution should not be used on cleaning the module.
• Always wear rubber gloves for electrical insulation
while maintaining, washing or cleaning panels.
• Deposits of foreign material on the frame surface
can be cleaned by using a wet sponge or cloth and
dried in air or by using a clean chamois.
I hope this helps. While I'm tempted, I really don't see myself climbing up on my sloped roof very often.[url]http://tinyurl.com/p37gryz[/url]Comment
