I had a solar team install and they were good for nothing. Trying to find out what micros are on each of the 4 breakers to make sure they did not break the max of 13 attached to each. I tried looking in the Enlighten app but could not find it. Any help would be appreciated. Thank you.
How can I see what microinverters are on each breaker in an Enphase combiner box?
Turn one breaker off, wait 16 mins (the reporting updates every 15 mins so make sure you go over 15), check the app array view.
Repeat for all breakers..... -
That’s what I thought but I still see all of them reporting regardless if the breaker is cutoff. Any reason this would be the case? I waited over 2 hours and none stopped communicating. Thanks for the help.Comment
Looks like there is an events page that I can use to show that no power is making it to these inverters. That should do the trick for this exercise. Appreciate the help here tremendously!Comment
