I am certain this has been covered somewhere but I can’t find it. I am looking at moving my small solar panel setup out to the edge of my yard. There are no shade structures there. About 150 feet. Can I use 10 or 12 gauge stranded wire inside conduit and add my own mc4 ends ? Or would a lower gauge be better and reduce the watt loss ?
Correct wire for 150 foot run to panels
Oops, right now 40 volts , 9 amps . I am planning to add another 2 200 watt panels in the future so then maybe double those numbersComment
For that kind of run you definitely want the panels in series, max
voltage and minimum current will seriously minimize losses. If
you will accept 3% (voltage) loss of around 4 V, at 9A and a 300
ft loop, Ohms law says no more than 0.44 ohms total, or .0015
Ohms per foot. So 12 ga could get by above, heavier to cut losses.
Bruce RoeComment
Good morning!
I went though this with our system installation. We had an addition built between our house and garage that we wanted to pre-wire for the solar before the panels went in. The only requirement that the vendor (Generac) required was that it be 3/4" EMT Conduit. We had to have about 70' run from the garage, through the addition and down into the utility basement where the inverter was placed.
The EMT conduit was a standard wire that the electrician was familiar with and able to source. The EMT conduit is the light green in the attached diagram (from our installation documentation).Attached FilesRade Radosevich-Slay
Tiverton, RIComment
Thanks for the responses. I think I may go back to my original plan of mounting them near the house and live with the slight early morning and late afternoon shading.Comment
Closest panels here are 500 ft from the house, adequate wiring
keeps total AC and DC losses to around 2%. Bruce RoeComment
2 Kw PV Classic 200, Trace SW 4024 460ah,Comment
Thanks, EXACTLY what I needed !!Comment
