Hi, Most of my items that I have Battery tenders on are near electric, I have one piece of a equipment that I can't get near a electric unless i run extension cords, Is there a solar panel I can get to plug a Battery tender JR into? I see Battery tender markets one but I was wondering if there was a slightly cheaper option. Thanks
Solar panel wanted to power a Battery Tender JR
Just be sure you get one big enough for the job, considering it
only functions a few hours a day, and hardly at all on cloudy days,
none under snow. I had a tiny one that plugged into the lighter,
but it was not enough to keep up with the small clock drain. I
pulled the fuse on the clock, except the lighter was on the same
fuse circuit.
I gave up and put a long cord on a maintainer. Best to be sure
there is NO drain from anything when shut down, if using a
solar maintainer. good luck, Bruce Roe -
