As I understand it, a 48v inverter does not begin to convert electricity until input >= 48v - is that correct? In order to get the inverter to start working earlier in the day, the 4x12v panels (hooked in series) will also need to be doubled or tripled or quadrupled (hooked in parallel)? Is this correct?
48v inverters
There are 2 types of inverters
Grid Tie inverters, which convert DC voltage into AC voltage, generating as much AC power as it can. They feed the Grid and rely on it to start up, and absorb the power. They will not run a off-grid house
Battery inverters, which run off a battery . They produce a stable voltage, and the current ( amps ) will vary as the house loads demand
3rd type - Hybrid inverters, which run off a battery but can also backfeed the grid. They don't care where their DC voltage comes from, battery, stable PV, or a wind/water turbine, but the
DC voltage must not sag. The battery is generally sized to keep the DC voltage stable.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Don't confuse Amps and Volts. More panels in parallel gives you more watts to work with which will increase your amperage so you can actually do something useful.As I understand it, a 48v inverter does not begin to convert electricity until input >= 48v - is that correct? In order to get the inverter to start working earlier in the day, the 4x12v panels (hooked in series) will also need to be doubled or tripled or quadrupled (hooked in parallel)? Is this correct?
Since you have 12V panels, they are probably so low wattage that the current available at 120VAC won't do much for you except power a radio or charge a cellphone. You may want to add a battery stack to concentrate your power so you can do more useful things with modest panels and also do them when the Sun isn't shining (i.e. at night).Comment
