Does anyone have any ideas if I mix in two REC 370 watt panels in a string that has 8 REC 350 watt together into a combiner
350 watt panels with rec 370 WATT PANELS
in a series string, my guess is the 370w would be reduced to 350w . I'm assuming same panel family, just binned into 350, 360 & 370 w catagoriesPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Best to do the math located in this article:
Mixing Solar Panels: Discover Now Dos and Dont's of Mixing the Same Types or Different Types of Solar Panels. Act Now to Save Your Money!
The more panels in the series the more the difference is skewed off.
Depending on the size of the build, could be cheaper to get a second SCC.Comment
If the current rating of the 370W is equal or slightly more than the other panels in
the series string, performance will be nearly identical to just adding more 350
watt panels. Bruce Roe
If there is a big difference, you may be able to do it and avoid the penalty by adding a Tigo optimizer to the panel
Mix and Match Different PV Module Types – Tigo Help Center (tigoenergy.com)
