I have a 10,000watt power jack 48v LF 120/220vac split phase power inverter with high standby current . I don't want to use it in power save mode.
I want to use it in normal mode and still have a low standby current draw.
Can I reduce the standby current significantly by installing an inductor inside and if yes where exactly should I place it and does the power jack comes with a built in inductor which I would have to bypass?
Here is a link for the inverter:
https://www.ebay.com/itm/26523320623...2b038052e135e9|enc:AQAGAAACAAzjp2g73yhKyw7FW8C0Mv82d9BP%2BX939%2 BkM7SEOPIzgzNLRB7I0bCT0m1cjCaNh%2B7EIWjZaGG46zCQFF grXUfRbvfu9d%2F%2B4oUP95JkwGujHFaMeTGcp0img0amlzEn pd2dL2X12IDbGTxrNeo9vFbfL%2BxknGoWEY2hy3woh4FkKjvd %2FqeGQ%2BQhejO3eFsLJNp9OuZ9z3yOX%2FQi%2B6OtE2IlH3 0%2BNvTgMlAyL8tHYEklt5AnfsdNhY7q9l4vz1VRQCHTHzQ70t rMCZCBetLRYsYrIez9%2FqFk4sqauCFVkNxBfkJLgo1HZdwwDA iY4pgdafgCjqTk30mMf1d4Aj8GJi6C%2BKVs1m%2BELuijnhIw %2FtRi3A31xVr7mu13dHq9fenvdAVLXdMd9KLSnybfDSD4Jyyk h2fdpGZHJmlkGgMLuMhbIpLg5sqZsldEqj%2Bv7xkFmA%2B4ZQ 88iXS1CHUTQ2lfzeP%2Fo2wK4n2xmgCzytu3NdQslR2sUA%2FM mwSxJFVPcZyINEkCpFD2lvwa6fHJgz%2FvkEBGW8STAwM7xQN6 %2BfksrBX%2FZWqwrIjqX2rn%2BX5dv4mWNBr53Of0wITqB%2B Nww%2Frhg2OWRPkzyvz4VxLVKVDdO2syXBARaUEeMcPQkNc3NT EQhMdAgyvGZrrud0P7fVy%2BnDxEjV9maGZiLlKU%2BfIbKdxf G|ampid:PL_CLK|clp:2047675
Here is the link for the inductor:
https://www.aliexpress.com/item/3304...27424c4dIyZcxr
