You will have to split the array to two 8Kw arrays. Multiple MPPT on one array will fight each other for control, and reduce your output.
Dumping PV into PTC heating elements
Thanks Mike!
I think the 8kW inverters are actually made up of two MPPTs, so I would have to split the 16kW into 4kW. The inverters are designed to work in parallel. Let me know if I've missed something.
On a separate note, these are very cool and might be good to throw into the mix - just not sure how to!
MPPT controllers for connecting PV direct to heating elements: https://www.polskieprzetwornice.pl/skle ... -3500w-proComment
