I had a PVS5x monitoring system that had been reporting data properly until Jan this year. All in a sudden it stopped reporting data and said the internet connection is lost. I did see that the PVS5x is not on my router's connected device list. However, the monitoring portal indicated the WiFi is connected and working, which I believe it's misleading and wrong. I couldn't even connect the LAN/installer port with my laptop, the port light was not blinking when I plugged in the Ethernet cable and sunpowerconsole.com was not accessible. So I contacted sunpower tech myself and they tried to remotely reset the WiFi connection but it was not successfully. Eventually I had the installer/dealer came out to do some troubleshooting with SunPower on the phone. It was then determine the unit is network component is dead and they will replace it with PVS6. A week later, installer came back and put on PVS6. The initial setup via the installer port worked fine until the point that it's self-updating the firmware. The initial version out of the box was 2019.04 and the console website got stuck on the firmware updating phase. Eventually it timed out and threw an error. The device LED indicator did blink blue first and then purple. After this, PVS6 was no longer connected to my WiFi (because I didn't see it on my router admin console) and also the installer port seems disabled. sunpowerconsole.com became inaccessible again just like my PVS5x and the port LED light does not blink at all with the Ethernet cable plugged in. installer decided to try a second PVS6 (he brought 2 units) but it's the same result -> initial setup went through fine with WiFi connected and it timed out during firmware update. installer port became disabled and WiFi dropped. Installer then called SunPower tech support and the tech support claims my system is working and can see it via my WiFi connection, which I believe its BS because I don't even see the device on my router's admin console)
With 3 failed units ( 1 x PVS5x and 2 new PVS6), it makes me believe that the latest SunPower monitoring firmware bricks/breaks the device.
If you have any similar issue, please share your experience and solution if you have any.
