Hi all,
How high would be the maximum charging voltage for 12v lead-acid batteries without causing damage to the battery?
I am currently using a 50amp PWM controller. Often times when Im home, I connect the panels directly to the batteries thinking it would charge faster. It is showing a faster increase in voltage on the battery.I do this only when I can keep an eye on the voltmeter.Once it reached 14V, I reconnect it again to the controller. Up to how high voltage can I let the panel directly charge the battery?
