MPPT Volts vs. Amps upon initial PV Array Config
  • Gpearston
    • Nov 2015
    • 22
    I have had off grid solar for several years, things are going pretty well.
    I recently added 2 additional 12v 100w Mono panels to my array. Now I have 6 panels. My controller is a EPEver MPPT controller.
    Presently, I have my panels in series so I am getting about 120v on open circuit and the controller does just fine. The controller's max voltage is 150.
    I am wondering if I am best served keeping the voltage as high as possible or if I am better off going with a 3Sx2P or even 2Sx3P. I am thinking that the highest voltage is probably best but wondering what others think.
    Doubt his has much bearing on it but I live in South Central Alaska so from late October to late February the solar output is minimal. I doubt anything will overcome that issue....
    Thanks
  • littleharbor
    • Jan 2016
    • 1998
    Depends on your battery bank voltage but given the potential cold temps I would go down to 3s2p to keep from overvolting your controller during a bright cold Alaska morning.
      Generally, the MPPT controller wants to see 1.5x battery voltage, for the most efficient downconversion. But, if you have a long cable run from PV to controller, you want higher voltage to get less loss in the expensive copper cable. So it's your call as long as you don't over volt the controller with a high Voc some bright cold morning
      • PNPmacnab
        • Nov 2016
        • 425
        If there are any shading issues, 3s2p may also work better.
        • Gpearston
          • Nov 2015
          • 22
          Thanks to all for the quick responses. I had completely forgotten about the cold allowing for higher voltage on the PV.
          3sx2p it is. Thanks again and happy harvesting.
          Glenn
