I'm not sure where this question belongs so I'm throwing it out here. Most calculations for panel output use "peak" solar power output. In my area it's about 5 hours a day. But, early in the morning say around 9am I'm getting at least 1 amp of power from my 100W panels. I'm curious why this power production isn't included into the calculations? There are 5 extra hours (2.5hrs in the morning and 2.5hrs at night) of non-peak power being put into the battery. In this case you are getting an additional 5A of power not accounted for.
Solar Power output-Peak Hours vs Total Hours
Solar production ramps up and then back down in a parabolic curve of potential. Sun Hours is a rule of thumb to calculate production so that you can simply multiply the sun hours by your wattage installed measured in STC power so in your case a 100w STC PV module times 5 sun hours comes up with 500wh
During your 5 hours you what you think is "peak" you are getting LESS than 100W from your PV module so the shoulder hours added in gets your rule of thumb estimate of 500Wh per day.
Amps does not work like you are talking and your calculations around amps is just not valid.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNH -
PV production modelling software, for example, e.g. PV Watts, do take into consideration the movement of the sun across the sky by latitude and month. Roughly speaking the shape of the production curve is an inverted parabola (more or less) assuming no other interfering factors (shade, clipping, etc.). That said, peak sun hours, usually no more than 3 to 5 hours per day (again varying by latitude and season), generally accounts for ~60-70% or more of your total production. Solar panels really only work well when the sun is essentially perpendicular from the face of the panel so orientation and inclination of the panel (and the sun in the sky) have a pretty significant impact.Comment
The amount of power is so low, and with some weather variation, not reliable to bother to count.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
peak is not a common term for sun hours. The common term it sounds like you are talking about is "Sun Hours"
Amps does not work like you are talking and your calculations around amps is just not valid.Comment
I know the extra power doesn't seem like much. But, in this case it actually is enough power to keep a charge on the battery with no load. I only referenced "Amps" because that's what indicated on the watt meter power analyzer. I'm not sure what the meter was measuring when it indicated "amps". I assumed it was amps.
further amps is kind of meaningless without knowing the exact voltage to convert to a storage capacity.
I am not implying that the power on the shoulders is meaningless but rather it is included in the sun Hour rule of thumb already.
OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Sun hours are a way of figuring how much power to expect of a fixed array. If you want to harvest more than 5 sun hours a day from your solar you can do one of two things.
1, Use a single or dual axis tracker. These tend to be costlier and require more maintenance than...#2
2, Virtual tracking which is to spend the money you would on a tracker on more solar panels and orient your panels to some degree east of due south and west of due south.. While you'll never see output of panels match your peak STC rating , your production day will last longer.2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
2, Virtual tracking which is to spend the money you would on a tracker on more solar panels and orient your panels to some degree east of due south and west of due south.. While you'll never see output of panels match your peak STC rating , your production day will last longer.Comment
