Hi everyone,
I'm in the process of choosing all the components to make a grid backup system.
For now, I have a Honda EU2200i (1800w continuous, 2200w peak) generator 120v and the utility grid split phase 240v/120v.
The first phase of the plan would be to have an split phase inverter/charger take over when the grid goes down.
I would like around 1-2h of autonomy on the battery (Probably lithium) and would start the generator for the rest of the grid power outage.
I have for about 3kW peak, 1kW continuous of critical loads (Fridge, sump pump, water pump, sewer pump, lighting).
I would also need 120v and 240v hence the split phase inverter.
The system should also be scalable for solar panels, more batteries, more power as eventually, I would like to be off grid.
Up to now, the inverters that would make sense for my requirements seems to be those one.
Each of them offer pros and cons and this is where I need your expertise!
- Outback Radian GS4048A-01:
- Schneider Conext SW4048
- Schneider Conext XW+ 6848
- Schneider Conext XW+ 5548
- Magnum MS4448PAE
The Outback and Conext XW are dual ac inputs so I could wire my generator on one of the input without the need of transfer switch.
BUT they only accept 240v so I would need a tranformer to step up to 240v.
On the other hand, the Magnum and the Conext SW have only one AC input but accept 120v. So I would add a transfer switch to use my generator.
BUT when using 120v input, I read they charge half power and maybe let ac through also half power (not sure).
I'm also wondering if there is a way to have a quick setting change for charger current limitation and AC going through as I'll have full 240v power on grid but limited power on generator 120v.
Having to fiddle with charger setting each time there is a power outage would suck.
Not sure about this option as there will be losses but I could also maybe DC couple my generator using a battery charger and just charge my batteries.
So, what do you think about all that? Which way should I go?
Do you know of a better inverter for my application?
thanks
Dan
- Magnum MS4448PAE
thanks
Dan
