From what I have been able to research, if I enclose my cells in a dry environment, then I will enclose only dry air and get no moisture build up on the inside of the enclosure. Is this a reasonable assumption?
yes provided what you enclose them in is impervious to water vapor and 100% impervious. leaving the cells in air with oxygen will degrade the cells eventually
Any idea what a threshold might be for a dry level. I sealed up a panel one morning 3 months ago when humidity was 35% and it is doing great. You think I could get by with 40 or 45%? I am using a silicon made for Acrylics and vinyl siding "J" channel around the perimeter. I am hoping to get a long life span out of it. What do you think?
neither material is resistant to water vapor. Eventually enough vapor will pass through the material to begin condensation.
Glass
Metal
oil base sealant (some)
very few plastics (teflon family, mostly)
