1) generally, the LOAD connection on the charge controller is only for a small LED night light or such. They usually cannot handle a lot of power.
2) breakers. The size of the wire you use, determines the size of the breaker to protect the wire.
I avoid fuses because if they blow, you have now spent $ on the original gear and a replacement fuse, usually more than a breaker costs. Good DC breakers are also able to be used as a switch for troubleshooting.
